Refinishing a Wood Prop
Old July 31st 08, 02:47 AM posted to rec.aviation.homebuilt
Kyle Boatright
Default Refinishing a Wood Prop
I've noticed that my prop is beginning to show signs of wear -chips in the
leading edge, and cracks in the clear finish. Given that I'm having shoulder
surgery in a couple of weeks (and probably won't be up to flying until the
arm is substantially healed), I should have some time on my hands to
refinish the prop.
My plan is to remove the existing finish by sanding with ~220 grit
sandpaper, then to use epoxy (with cabosil?) to fill any dents, etc, and
sand/scrape the repaired areas back to the appropriate profile. Also, I
plan on doing some repair work to the leading edge which is an epoxy based
product. On the leading edge, I'll probably grind into any damaged areas,
then fill with one of the putty type epoxies and sand/scrape to the correct
profile, finishing with a very fine sandpaper.
Finally, I'll check the balance of the prop before finishing, and adjust
balance by either a little more sanding on the heavy blade or an extra coat
or two of urethane on the light blade.
What steps have I missed, and are there any fine points I'm missing?
Thanks in advance,
Kyle
Old July 31st 08, 03:24 AM posted to rec.aviation.homebuilt
Gerry Caron
"Kyle Boatright" wrote in message
shoulder surgery in a couple of weeks (and probably won't be up to flying
until the arm is substantially healed), I should have some time on my
hands to refinish the prop.
Don't know what brand of prop you have, but the manufacturer should have
some guidance available. Sensenich provides the following:
http://www.sensenichprop.com/sen_htm...stall/cf-a.pdf
correct profile, finishing with a very fine sandpaper.
coat or two of urethane on the light blade.
On the Sensenich web site "repair info" page, it states that they repair
props IAW AC43.13-1B, so you might check it out (under wood repair and
finishing.) Also they Care and Feeding doc (above link) says that they use
spar varnish for the finish.
Gerry
Old July 31st 08, 03:19 PM posted to rec.aviation.homebuilt
On Jul 30, 6:47 pm, "Kyle Boatright" wrote:
Hey, Kyle...
Don't laugh, but give JB Weld a try :-)
Yeah, I know... hell of a ding. Big enough so that we're talking real
divots here. The patch had to have some serious structural strength.
Used a dental pick to create a key, added the JB Weld in three
applications, about twenty minutes apart, coarsely finished with a
rasp between layers 1-2 & 2-3. Let it cure about a week.
Use the water trick to make sure you've got the contour right. (ie,
arrange the thing so a flow of water across the divot catches the
light, tells you when there's no difference in contour between the
original surface and the divot. Use a sponge. W&D paper on a
stick.) All cleaned up (your FINGERS are more accurate than your
eyes), you can return the balance to near-zero by tapping lead foil
into a drilling on the tip, to zero-zero with PAINT when you blacken
the back-side.
I'm sorry to hear about the arm but damn happy to know it isn't
catching :-)
-Bob
Old July 31st 08, 06:38 PM posted to rec.aviation.homebuilt
Copperhead144
Hey, Kyle...
Yeah, I know... hell of a ding. *Big enough so that we're talking real
divots here. *The patch had to have some serious structural strength.
rasp between layers 1-2 & 2-3. *Let it cure about a week.
Use the water trick to make sure you've got the contour right. *(ie,
light, tells you when there's no *difference in contour between the
original surface and the divot. *Use a sponge. *W&D paper on a
stick.) *All cleaned up (your FINGERS are more accurate than your
the back-side.
catching :-)
-Bob
I don't know what part of the countryyou live in Kyle but if you were
close to TN I'd make a trip to your homebase and help out just to pull
a mold off half of your prop. :-).FWIW don't rule out having a local
E.A.A. chapter member that's into prop building hellping you out in
exchange for the opputunity to make a duplicate of your prop.
Joe
Old July 31st 08, 11:40 PM posted to rec.aviation.homebuilt
Kyle Boatright
"Copperhead144" wrote in message
Hey, Kyle...
the back-side.
catching :-)
-Bob
Joe
I'm based at VPC - Cartersville, GA, which is about 30 miles NW of
Hartsfield Jackson. I live right off I-75 in Marietta, just outside the
perimeter highway for Atlanta...
If you're still interested in making a mold, drop me a line. By the way,
what does one do with a prop mold?
KB
Old August 1st 08, 01:16 AM posted to rec.aviation.homebuilt
On Jul 30, 6:47*pm, "Kyle Boatright" wrote:
(snip)
Kyle ..........
Shoulder surgery, hmmm. . . I remember three months after mine I was
finally able to lift my arm enough to wash underneath without using a
stick. Good luck on the sanding!
I used an electric random orbiltal on my Sterba prop and was surprised
at the irregularities in the surface. I just kept at it until all the
original varnish was gone and the last dip was sanded smooth, then
finished up to a 320 grit. I figured that all that sanding might
either improve the efficiency or thin the airfoil enough to increase
the rpm a bit. Neither one happened - I couldn't tell a bit of
difference.
The leading edge on a Sterba prop is made from a softer urethane
material that resists dings and it didn't need repair. Some tips on
wood prop maintenance are available he http://www.greatplainsas.com/edmtce.html
When I was satisfied with the quality of the spray can urethane
finish, I made a steel "spud" that fit the center hole. I constructed
a wood jig in the shape of a "U", cut two grooves in the top edges and
inserted two extra blades from my jointer. Then I could lay the prop
in the jig with the spud resting on the sharp edge of the jointer
blades. One extra coat on one blade of the prop and it balanced.
Rich S.
Old August 1st 08, 05:40 PM posted to rec.aviation.homebuilt
Copperhead144
Hey, Kyle...
the back-side.
catching :-)
-Bob
Joe
Hartsfield Jackson. *I live right off I-75 in Marietta, just outside the
If you're still interested in making a mold, drop me a line. *By the way,
KB- Hide quoted text -
- Show quoted text -
Hmmm! Your about a three hour drive from my location, let me check my
schedule and I'll get an e-mail to you. Now, with regard's to a mold
of the prop, you use the split mold to cast a copy of the mold, smooth
it up if necessary and then use it as a master in a propeller
duplicator. Or at least I hope so any way, I'm researching the heck
out of prop building and mapping out plans for a propeller duplicator.
Blame it all on Bob Hoover, he's got me believing I can do the
impossible. :-). It's nice when people encourage you to try new things
and reachout a bit further isn't it?
Joe
Old August 10th 08, 05:08 AM posted to rec.aviation.homebuilt
dpilot
Hey, Kyle...
the back-side.
catching :-)
-Bob
Just a nit to pick on here.
The "back" side of a prop is the side the pilot cannot see
The "front" side of a prop is the side that you should "blacken"
JimV.
Old August 10th 08, 01:27 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Sat, 9 Aug 2008 21:08:23 -0700 (PDT), dpilot
Hey, Kyle...
the back-side.
catching :-)
-Bob
JimV.
only on a pusher....
Old August 10th 08, 05:16 PM posted to rec.aviation.homebuilt
On Sun, 10 Aug 2008 20:27:24 +0800, Stealth Pilot
Jim should have used "Face" instead of "Front," but the "Back" side of the blade
is indeed the side the pilot cannot see. Think relative wind. When the engine
is turning the prop on a tractor engine, the side the pilot CAN see is the side
that is impacted by the oncoming air. Only when the engine is windmilling does
the relative wind hit the side of the blade seen from in front.
This is a boat site, but it illustrates the issue:
http://www.propline.com/Propeller-Ge...erminology.htm
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Wood Prop Question [email protected] Home Built 0 April 18th 07 10:01 AM
Wood Prop Question [email protected] Home Built 0 April 18th 07 05:42 AM
Refinishing wooden prop Wallace Berry Home Built 4 December 17th 05 03:10 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
