Motorglider Definition
Old December 6th 08, 07:27 PM posted to rec.aviation.soaring
Doug Hoffman
Default Motorglider Definition
In a Yahoo group, MinimalistAirplaneStudyGroup, it has been asserted
that a homebuilt aircraft registered as experimental can be registered
as a motorglider, regardless of wingspan and gross weight capacity.
For example, one could build something like the 18 foot wingspan, 550
pound maximum gross weight Hummelbird and call it a motorglider. One
could then fly it having only a Private Pilot Glider license with
self-launch endorsement.
It was also asserted that the 0.62 lb/ft^2 (max gross/span^2)
requirement does not apply to homebuilt aircraft registered as
experimental motorglider. One could even have two engines/props and
still fly it using only a PPG ticket.
The following was provided as proof of the assertion:
http://edburkhead.com/Challenger/gli...torglider1.htm
However, I remain skeptical that the FAA would allow this. Any thoughts
from someone here with knowledge or experience? TIA
Regards,
-Doug
Definition of CFIT? Roy Smith General Aviation 4 March 31st 08 04:00 PM
Definition of a Veteran? Otis Willie Naval Aviation 0 March 26th 07 10:49 PM
Need A Definition Jay Beckman Piloting 4 May 11th 04 04:41 PM
Inflight Emergency -- Definition Chris OCallaghan Soaring 13 March 2nd 04 07:09 PM
Cross-Country Definition (USA) Michael Stringfellow Soaring 16 February 9th 04 05:01 PM
