On Thu, 26 Jun 2008 20:39:09 -0700 (PDT), et
wrote: Is there an easy way for a novice to check an old antenna? thanks et use it connected to a radio. the most likely issue will be corrosion to the screw threads on the base which increases the resistance. the base and threads should be brass which will clean up quite nicely with brasso and a toothbrush. ....now of course you do have a mental picture of the antenna that I'm thinking of dont you... Stealth :-) Pilot |
| Thread Tools | |
| Display Modes | |
| GPS Antenna | 150flivver | Owning | 14 | December 11th 05 06:38 AM |
| Best VHF Antenna | Steve | Home Built | 6 | January 25th 05 03:04 PM |
| ELT Antenna | Gary | Home Built | 18 | November 5th 04 03:17 AM |
| VHF Antenna | David Wilson | Home Built | 1 | June 14th 04 04:25 AM |
| ADF antenna | Dan Luke | Owning | 3 | August 14th 03 03:48 PM |
