Soda Blasting
Old June 25th 06, 02:40 PM posted to rec.aviation.homebuilt
Default Soda Blasting
I'm repainting a fiberglass airplane.
Sanding the wings, once removed from the plane is a fairly easy chore,
however sanding the underside of the fuselage and strakes is going to be
a major chore.
A body shop near the airport has a soda blaster that they will let me
use. I've heard of folks using these to remove old paint from boats and
planes.
Is it possible to use a soda blaster to remove only the top coat and not
remove the primer and micro beneath??? Basically use it to do the 60
grit sanding job and then follow with the relatively easier 150 and 240
grit sanding to prepare for primer?
Anybody do this and actually save time and effort?
Scott
Looking for a DER/Structural mhorowit Home Built 3 June 25th 06 04:33 AM
Temporary, portable sand blasting 'cabinet'?? Michael Horowitz Restoration 1 April 23rd 06 03:41 AM
Abrasive blasting references? Mike Restoration 1 April 6th 06 03:50 PM
Blasting and painting [email protected] Home Built 7 June 3rd 04 03:14 PM
