Question On Rudder Cables
Old June 24th 12, 02:32 PM posted to rec.aviation.soaring
John Sinclair[_4_]
Default Question On Rudder Cables
At 02:03 24 June 2012, T wrote:
On Jun 22, 10:04=A0am, wrote:
In a May 10 posting on Rudder Cable Systems JJ had a great list of
things=
to check on during annual inspections. Item #1 dealt with the nylon
sleeve=
in the "S" tube that prevents metal-to-metal contact. While working on
my
DISCUS B yesterday I noticed that the nylon sleeves on both "S" tubes had
m=
igrated aft -- out of the top of the "S" tube, resulting in
metal-to-metal
contact at the lower end of the "S" tube. Tried to shove them back in but
t=
o no avail. Is there a magic way to correct this situation?
Want to fix this before flying again.
Mike J.
You may need to disconnect one end of the rudder cables to remove
tension in the "S" to allow the tube to be pushed back into position.
It would be a good time to thoroughly inspect the cable for wear or
frayed cable end sticking out that may have slowly pushed the tube out
of position.
T
Mike,
You need a way to get some pressure on the nylon tube and force it back
into the 'S' tube. You might try clamping two little wood blocks on the
cable where it exits the nylon tube (held in place with a 'C' clamp), then
heat up ehe 'S' tube with a heat gun and then pull back on the rudder pedal
adjustment. The wood blocks won't let the rudder pedals move, but will
place pressure on the nylon tube, forcing it back where it belongs
(hopefully)............... give it a try, it's better than replacing the
rudder cables in order to get the tube back where it belongs!
Cheers,
JJ
Question - rudder flutter ? Bravo Two Zero Piloting 47 December 27th 07 01:31 PM
Pegasus Rudder Cables? Bill[_9_] Soaring 10 June 28th 07 07:43 AM
unsticking cables dlevy Owning 12 January 8th 06 09:39 AM
MiG-29 cables alcatraz Military Aviation 0 March 1st 04 10:01 PM
rudder cable question Bob Loer Home Built 7 November 26th 03 08:34 AM
