A Poll on your weight and balance
Old December 6th 12, 02:19 PM posted to rec.aviation.soaring
Andy[_1_]
Default A Poll on your weight and balance
On Wednesday, December 5, 2012 11:55:17 AM UTC-7, JS wrote:
Going by just tail weight, perhaps Martin Heide has friends who are chiropractors.
I suspect Martin just inherited this design feature. My 28 runs about 60lb on the tail, ballasted and with me in the cockpit. I have to lift a lot more than that to put the tail dolly on. I have no record of the tail weight for that condition but it calculates to approx 90lb.
Attempting to answer the OP's question - In specified weighing attitude, no ballast and no pilot, tail 67lb. Same with pilot and chute in cockpit, tail 37.5lb.
As others have pointed out, the conditions for measuring tail weight have a huge influence on the result. No data will be of any value unless the conditions are specified.
Andy (GY)
Old December 6th 12, 02:38 PM posted to rec.aviation.soaring
Grider Pirate[_2_]
I suspect Martin just inherited this design feature. *My 28 runs about 60lb on the tail, ballasted and with me in the cockpit. *I have to lift a lot more than that to put the tail dolly on. *I have no record of the tail weight for that condition but it calculates to approx 90lb.
Attempting to answer the OP's question *- In specified weighing attitude, no ballast and no pilot, *tail 67lb. *Same with pilot and chute in cockpit, tail 37.5lb.
As others have pointed out, the conditions for measuring tail weight have a huge influence on the result. *No data will be of any value unless the conditions are specified.
Andy (GY)
Janus C - 64 lbs
Speed Astir II - 90 lbs
Old December 6th 12, 03:02 PM posted to rec.aviation.soaring
John Carlyle
ASW-19B = 70 lbs
LS8-18 = 67 lbs
Both values without pilot or chute, and both done using manufacturer's specified tail position.
-John
Old December 6th 12, 06:00 PM posted to rec.aviation.soaring
RN
DG-1000 109 lbs without tail weights and empty cockpits
Old December 7th 12, 09:32 PM posted to rec.aviation.soaring
soartech[_2_]
THANKS ALL for your helpful info.
I was simply trying to determine if my glider had a typical tail wheel
weight.
The first time I tried to lift the tail to install a dolly I was
dismayed to discover
how heavy it is. All I had to compare it with is the club fleet of
three SGS machines which all
have very light tail weights. It seems as if the older gliders
(Cherokee, 1-26, 1-34) are
almost balanced on the wheel whereas the glass ships are quite heavy.
Does this make them any trickier to land? I realize the flying
balance
is most likely different from wheel balance i.e CG and wheel are not
co-located.
The average of the single place tail weights without pilot aboard is
66 lbs. and mine
is 72 lbs. so I am right in the ballpark.
Has anyone made a simple lever-lifted dolly arrangement? Or do you
risk your back with
the poor lifting position that the tail boom presents?
Old December 7th 12, 09:45 PM posted to rec.aviation.soaring
Grider Pirate[_2_]
I just risk my back. The Speed Astir 'Dolly' is just a post on a
wheel. That's nice, because you can't accidentally take off with it
on, but lifting that 90 lb tail and trying to fit the post into the
hole in the underside of the fuselage can be challenging.
The Janus uses a conventional dolly and has only 64 lbs on the
tailwheel. Piece of cake.
BTW, on the subject of weight and balance, just for your own knowledge
you might want to run the numbers with your tail dolly ON. In the
case of the Janus, the glider remains well within CG limits unless it
is being flown solo by a person that is lighter than me, or any of my
partners.
weight.
Does this make them any trickier to land? *I realize the flying
balance
co-located.
66 lbs. and mine
risk your back with
Old December 7th 12, 10:33 PM posted to rec.aviation.soaring
Dave Nadler
Of course:
http://www.cobratrailer.com/catalog/...roducts_id=144
Old December 7th 12, 11:56 PM posted to rec.aviation.soaring
Bob Gibbons[_2_]
On Fri, 7 Dec 2012 13:32:41 -0800 (PST), soartech
.... text deleted
risk your back with
I'd recommend Mark Mocho's combination tow dolly with integrated lift
bar.
http://www.mmfabrication.com/towbars.htm
A very satisfied user.
Bob
Old December 8th 12, 12:31 AM posted to rec.aviation.soaring
weight.
balance
co-located.
66 lbs. and mine
risk your back with
I agree with Bob's comment about Mark Mocho's tow bar and tail boom lifter. It works very well and there are at least 30 or 40 satisfied users at Moriarty and there are many other users around the US! His website is: www.mmfabrication.com
Old December 8th 12, 01:14 AM posted to rec.aviation.soaring
weight.
balance
co-located.
66 lbs. and mine
risk your back with
As weighed when I took delivery of my plane the tail wheel had 71 lbs on it.
I added 6 lbs of ballast back there. When I'm in the plane the CG is about
7.5 inches behind the main wheel. Of course all this is with the plane
leveled; since the plane normally sits tail down more weight shifts aft.
The position of the CG is normal for these kind of tail dragger planes.
Schweitzers (other than the 1-35) and typical glass trainers (K21 or G103)
are nose draggers when occupied.
What I do to put on or take off the tail dolly is to straddle the tail boom
facing aft. After I pick up the boom I cross my ankles under the boom so
I easily hold it up while messing with the dolly.
-- Matt
-- Matt
ASK-21 Weight and Balance Carl Baxter Soaring 4 June 2nd 11 02:57 PM
PA-32 Weight and Balance John Doe Owning 14 May 23rd 06 01:03 AM
L23 weight and balance Tony Verhulst Soaring 5 December 31st 05 01:54 AM
Weight and Balance Dale Larsen Home Built 2 June 23rd 04 05:11 PM
Weight and Balance JP Piloting 2 January 13th 04 10:54 AM
