Looking for a trailer wheel
Old March 27th 14, 01:09 AM posted to rec.aviation.soaring
Bob Kuykendall
Default Looking for a trailer wheel
I just did a bit of web searching, and I now believe that "ET27" refers to an offset of 27mm or 1-1/16". Given the width of 4.5", I think that for most steel wheels that would correspond to a backspacing of 3.81".
If that is so, now all you need is the bolt circle. The best bet is to measure it as I wrote earlier. Although, if it is a European glider trailer, I would put my money on 4-on-108mm.
Thanks again, Bob K.
Old March 27th 14, 10:09 PM posted to rec.aviation.soaring
GC[_2_]
I wrecked a Cobra wheel recently from a two-seater trailer (15" wheel, 5
bolts) and I found measuring the PCD wasn't simple or easy. There are a
number of very-close-to-what-I-think possibilities and only the
templates that some trailer dealers seem to have make accurate decisions.
The other difficulty is that trailer wheels are rarely the same as car
wheels these days. The near-universal use of bulky disc brakes on cars
and drums on trailers means that the offset on car wheels is usually
larger than that on trailer wheels. Visiting your local wrecker can be
time-consuming and frustrating. So close but no cigar!
My offset was 30 and I'll be surprised if the OP can find a car wheel to
match his offset of 27.
GC
Old March 28th 14, 05:24 AM posted to rec.aviation.soaring
Bastoune
My Komet III trailer has a rims with the following marking:
4 1/2 Jx13H2 and ET27
The bolt spacing on these is 4x100mm
good luck.
Jockey wheel for PIK-20 trailer lynn Soaring 1 November 23rd 12 07:16 AM
Komet trailer wheel bearings Dan[_6_] Soaring 7 February 9th 09 06:13 AM
truck + 5th wheel RV + glider trailer ?? Steve Koerner Soaring 16 March 27th 07 03:44 AM
Avionic trailer wheel needed qflyer1 Soaring 6 December 7th 06 03:30 PM
Q about trailer wheel bearings Ken Ward Soaring 1 September 15th 06 02:40 AM
