MKIII yaw string sale
Old November 28th 15, 12:02 AM posted to rec.aviation.soaring
Default MKIII yaw string sale
On Friday, November 27, 2015 at 10:58:06 AM UTC-5, bumper wrote:
On Friday, November 27, 2015 at 7:02:53 AM UTC-8, Dan Marotta wrote:
You could make a hole in the forward part of the canopy so the
internal strings could get an idea of which way the wind is
blowing...
Dan, 5J
Dan,
Brilliant!
I think you are onto something. However, we might get the same functionality without that drafty hole by training the MKIV's to work as a team. There'd be one inside and one outside, both with tiny magnets so their tails stay aligned. That way when the canopy is all iced up and you can't see a thing outside, you'll still be able to take comfort in knowing which way the wind is blowing as you are falling out of the sky - that being mostly down of course.
bumper
Ummmmmm..... [sarcasm]..... next you'll say, "I need an app to fly IFR when I can't see through the canopy ice/frost"..... then you will get flamed, thus likely providing enough heat (from replies) to melt the ice/frost so you can see again (provided you didn't get stuck in clouds...) [/sarcasm]
BTW {again.... sarcasm....], yaw string (whatever version) is "relative wind", sorta helps with aerodynamics, not so much with terrain [/sarcasm]
OK, so I really tried to "toe the line" on legal as well as prudent.
I'm really hoping most of this thread is "tongue in cheek", sorry to be a "Debbie downer" for those that wanted to spend money for the "latest & greatest" (not that it wouldn't help some....).
Done.
Nomex suit on.
Old November 28th 15, 03:22 PM posted to rec.aviation.soaring
Dan Marotta
Cloud flying comes of age in the USA!
Of course you'll need a small reservoir filled with a 50/50 mix of
antifreeze and distilled water and a small nuclear powered pump to keep
the external string free from ice. Hmmmm... Should that be a closed
system or a total loss system as in early motorcycle primary chain
lubrication systems? Perhaps the power source for the pump could also
be pressed into service heating the pilot's socks and eliminating those
pesky lead-acid batteries. Properly located, it could also serve as a
birth control device.
Oh, how I love the low ceiling, snow, and ice...
Dan, 5J
blowing...
Dan, 5J
Dan,
Brilliant!
bumper
Dan, 5J
Clear Yaw string tape? Bruno Soaring 42 August 30th 13 05:56 PM
Improvements to MKIII and Quiet Vent bumper Soaring 1 January 16th 09 03:29 PM
Wikipedia:Yaw string Doug Haluza Soaring 18 January 30th 07 02:52 PM
Yaw String in a Spin John Galloway Soaring 52 January 21st 05 10:14 PM
Yaw String refference - Spinning Vassilios Mazis Soaring 1 January 18th 05 07:30 AM
