On Tuesday, August 17, 2010 at 9:21:26 PM UTC-5, Tony wrote:
On Aug 17, 7:41Â*pm, BTiz wrote: On Aug 17, 7:56Â*am, Tony wrote: Curious, Sporting Code 3 defines the Ultralight Class as a take off weight of less than 220 kg, or 485 lbs. Â*Is this maximum allowed takeoff weigth or the actual weight of the glider for that flight? Tony... as I read the sporting code.. they always refer to "Mass", whether it be max or minimum attainable. So to me, in the US to read, "ULTRALIGHT, a glider with a takeoff mass not exceeding 220 kg," that means maximum gross weight. Are you considering that you can get an ULTRALIGHT record if you can fly your glider below 220kg, even if you can actually carry more according to the TCDS? Perhaps a letter to the FAI or the SSA Badge Lady is needed? BT The sporting code does not have different meaning in the US vs. other countries. Not me, but I think there is a possibility that a light person in Leah's Cherokee II would be under the Ultralight limit and the Feminine World Record for Free Distance in the Ultralight class is only 150ish kilometers. There are NO US Feminine records in the Ultralight class. Go Leah, GO! |
Motorglider Definition | Doug Hoffman | Soaring | 0 | December 6th 08 07:27 PM |
Definition of CFIT? | Roy Smith | General Aviation | 4 | March 31st 08 04:00 PM |
Definition of a Veteran? | Otis Willie | Naval Aviation | 0 | March 26th 07 10:49 PM |
Need A Definition | Jay Beckman | Piloting | 4 | May 11th 04 04:41 PM |
Cross-Country Definition (USA) | Michael Stringfellow | Soaring | 16 | February 9th 04 05:01 PM |
