Tost Lilliput brake question
Old May 21st 19, 05:28 PM posted to rec.aviation.soaring
Tim Taylor
Default Tost Lilliput brake question
In general you will also find that there is not enough movement in the handle to move the arm far enough to provide adequate braking unless the brake is adjusted to touching the drum at rest. After deglazing, I adjust the cable until there is a light dragging with with the handle in the fully open position. The handle should have almost no movement to provide full braking.
Looking for Tost Standard Drum Brake Wheel (USA) [email protected] Soaring 2 March 28th 19 12:11 PM
Modifying Std Libelle with Tost Lilliput Wheel [email protected] Soaring 10 September 19th 17 06:51 PM
Tost Disk Brake rebuild? Paul Cordell Soaring 10 April 17th 08 07:20 AM
Tost brake bolt shears off - the answer Jack Glendening Soaring 1 September 30th 07 01:16 PM
Tost brake bolt shears off Jack Glendening[_2_] Soaring 25 September 10th 07 10:15 PM
