#21
In article , Stefan
writes Ian Strachan wrote: The standard recovery procedure once a full spin has developed that works for most aircraft is, It doesn't work in "most" aircraft, but rather in *all* aircraft which are JAR certified. In fact, for an aircraft to get JAR certification, this method must recover from a spin of at least five full rotations. (If the CG is within the stated limits, of course!) Glad to hear it. I try to be cautious in my posts and not to say things that could be shot down and reduce the impact of the main points that I am trying to make. In this case that deliberate fully-developed spinning at low level below bale-out height has questionable training value compared to spinning at a safe height, is extremely foolish, and does no credit to our sport in the eyes of others. -- Ian Strachan |
Ian Strachan wrote:
In this case that deliberate fully-developed spinning at low level below bale-out height has questionable training value compared to spinning at a safe height, is extremely foolish, No question about this. I never start a deliberate spin (or even try the stall behaviour of an unknown plane) below 3000 ft AGL. Stefan |
In article , Stefan
writes Ian Strachan wrote: In this case that deliberate fully-developed spinning at low level below bale-out height has questionable training value compared to spinning at a safe height, is extremely foolish, No question about this. I never start a deliberate spin (or even try the stall behaviour of an unknown plane) below 3000 ft AGL. Stalling, in the sense of a cautious and gradual approach to the stall, is another thing entirely, quite different to a full autorotative state in a downward direction. But you are right to be cautious, particularly with any "unknown quantity" be it a glider, powered aircraft, high performance jet, or whatever. At the stall, stick forward to reduce alpha, pause for airspeed to build, then normal use of aileron to level wings as necessary, is my recommended action in most types of aircraft. Note, no use of coarse rudder. Coarse rudder applied near the stall can often lead to, guess what? A S ...... P ....... I ........ N Surprise, surprise ....... Myself, in a glider environment, a slow approach to a stall and a quick recovery, starting from 1500 ft AGL is OK. In a glider with known and reasonable characteristics, 1000 ft. The difference to a fully-developed spin is very marked, no comparison, really. -- Ian Strachan |
Ian Strachan wrote:
Stalling, in the sense of a cautious and gradual approach to the stall, is another thing entirely, quite different to a full autorotative state in a downward direction. Yes. But part of my stall behaviour exploring is if, and if yes, when and how does the glider drop a wing? Can it be held, fully stalled, with the rudder? If yes, I push the stick forward and everyting is fine. If no, guess what happens? Stefan |
In article , Stefan
writes snip when and how does the glider drop a wing? Can it be held, fully stalled, with the rudder? But why try it in the first place? Of what benefit does it have to training people in rapid recovery from the stall situation? What are we trying to achieve? I would suggest that primarily it is training for rapid stall RECOVERY. Not playing around with whether or not we can hold the aircraft in the stall with a combination of unusual control positions. That is test flying, not legitimate instruction of less experienced pilots for their future benefit. Surely, we are discussing how best to teach early gliding students, both pre-solo and just after solo. That is the critical area. You and I can no doubt do all sorts of interesting things at the stall and into the fully developed spin. Hopefully we may know what we are doing and will not come to disaster. But this is experienced-pilot-academia, not how the less experienced people in our sport should be taught how to avoid potentially dangerous situations. "Stories about what the highly experienced pilot can get away with are often dangerous to those that are less experienced". -- Ian Strachan |
Yes, that's true.
And, highly experienced pilots don't always get away with it either. Recalling a tragic loss of two well known and respected pilots in a Nimbus 4 a few years ago. "Ian Strachan" wrote in message ... In article , Stefan writes snip when and how does the glider drop a wing? Can it be held, fully stalled, with the rudder? But why try it in the first place? Of what benefit does it have to training people in rapid recovery from the stall situation? What are we trying to achieve? I would suggest that primarily it is training for rapid stall RECOVERY. Not playing around with whether or not we can hold the aircraft in the stall with a combination of unusual control positions. That is test flying, not legitimate instruction of less experienced pilots for their future benefit. Surely, we are discussing how best to teach early gliding students, both pre-solo and just after solo. That is the critical area. You and I can no doubt do all sorts of interesting things at the stall and into the fully developed spin. Hopefully we may know what we are doing and will not come to disaster. But this is experienced-pilot-academia, not how the less experienced people in our sport should be taught how to avoid potentially dangerous situations. "Stories about what the highly experienced pilot can get away with are often dangerous to those that are less experienced". -- Ian Strachan |
Ian Strachan wrote:
But why try it in the first place? Well, how about ... curiosity? After all, gliding is about fun and not rationalism. Stefan |
#29
On Fri, 14 Jan 2005 19:41:29 UTC, Don Johnstone
wrote: : Spot on Ian. The rules for the Air Cadets in the UK, : RAF rules, prohibit intentional spinning below 2500ft : in a glider. If you are still spinning you abandon : at this height How many gliders will not recover from a spin with 2,500' to spare? What are the injury rates for parachute jumps from gliders? Ian -- |
#30
At 11:00 18 January 2005, Ian Johnston wrote:
On Fri, 14 Jan 2005 19:41:29 UTC, Don Johnstone wrote: : Spot on Ian. The rules for the Air Cadets in the UK, : RAF rules, prohibit intentional spinning below 2500ft : in a glider. If you are still spinning you abandon : at this height How many gliders will not recover from a spin with 2,500' to spare? Nobody living can answer that question What are the injury rates for parachute jumps from gliders? How many people survive spinning in? Ian -- |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Who's At Fault in UAV/Part91 MAC? | Larry Dighera | Instrument Flight Rules | 24 | April 29th 04 04:08 PM |
| Single-Seat Accident Records (Was BD-5B) | Ron Wanttaja | Home Built | 41 | November 20th 03 06:39 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
