FAI Ultralight Definition
Old August 17th 10, 03:56 PM posted to rec.aviation.soaring
Tony[_5_]
Default FAI Ultralight Definition
Curious,
Sporting Code 3 defines the Ultralight Class as a take off weight of
less than 220 kg, or 485 lbs. Is this maximum allowed takeoff weigth
or the actual weight of the glider for that flight?
Old August 18th 10, 01:41 AM posted to rec.aviation.soaring
BTiz
On Aug 17, 7:56*am, Tony wrote:
Curious,
less than 220 kg, or 485 lbs. *Is this maximum allowed takeoff weigth
Tony... as I read the sporting code.. they always refer to "Mass",
whether it be max or minimum attainable.
So to me, in the US to read, "ULTRALIGHT, a glider with a takeoff mass
not exceeding 220 kg," that means maximum gross weight.
Are you considering that you can get an ULTRALIGHT record if you can
fly your glider below 220kg, even if you can actually carry more
according to the TCDS?
Perhaps a letter to the FAI or the SSA Badge Lady is needed?
BT
Old August 18th 10, 03:21 AM posted to rec.aviation.soaring
Tony[_5_]
Curious,
BT
The sporting code does not have different meaning in the US vs. other
countries.
Not me, but I think there is a possibility that a light person in
Leah's Cherokee II would be under the Ultralight limit and the
Feminine World Record for Free Distance in the Ultralight class is
only 150ish kilometers. There are NO US Feminine records in the
Ultralight class.
Old August 18th 10, 04:55 AM posted to rec.aviation.soaring
BTiz
Curious,
BT
countries.
only 150ish kilometers. *There are NO US Feminine records in the
Ultralight class.- Hide quoted text -
- Show quoted text -
That may be worth chasing, you would probably have to have a certified
weight taken just prior to take off. That extra bottle of water may be
too much.
Not many "ultralight gliders" in the US until they built the
SparrowHawk.
Old August 18th 10, 05:29 AM posted to rec.aviation.soaring
sisu1a
SparrowHawk.
There's still more Carbon Dragons than SparrowHawks... nearly 2/1
IIRC (might not all be in US, hmm), but even added together it's still
not many... Gary Osaba knows a great deal about the fine lines of the
sporting code on ultralights if you contact him... Also Leo Benitti
set a respectable one of TX in a too and would know the nitty gritties
and I'm sure would be glad to help if you contacted him.
relevant: http://records.fai.org/docs/9635-4.pdf
His Silent was 281lbs empty for the flight, within D/U limits. If it
were the motorglider version, it would have been 140lbs heavier and I
think out of weight for the category. You should be able to
extrapolate whether Leah and her Cherokee are too fat for this
category or not. If they are over however, I recommend different
verbiage to convey this point
-p
Old August 18th 10, 01:19 PM posted to rec.aviation.soaring
Tony[_5_]
SparrowHawk.
There's still more Carbon Dragons than SparrowHawks... * nearly 2/1
not many... *Gary Osaba knows a great deal about the fine lines of the
relevant:http://records.fai.org/docs/9635-4.pdf
His Silent was 281lbs empty for the flight, within D/U *limits. If it
-p
not to mention there are a few woodstocks out there.
Good point Paul, I'll check in with Gary and Leo. I had read Leo's
flight report in Soaring, what a story.
Old May 8th 17, 03:25 AM posted to rec.aviation.soaring
K Smith[_2_]
On Tuesday, August 17, 2010 at 9:21:26 PM UTC-5, Tony wrote:
On Aug 17, 7:41Â*pm, BTiz wrote:
On Aug 17, 7:56Â*am, Tony wrote:
Curious,
less than 220 kg, or 485 lbs. Â*Is this maximum allowed takeoff weigth
BT
countries.
Ultralight class.
Go Leah, GO!
Old August 18th 10, 08:57 AM posted to rec.aviation.soaring
Alan[_6_]
In article BTiz writes:
On Aug 17, 7:56=A0am, Tony wrote:
Curious,
less than 220 kg, or 485 lbs. =A0Is this maximum allowed takeoff weigth
Much of the world does not report weights of things, but they report
masses in kilograms (or grams). A mass of 220 Kg would "weigh" 485 pounds.
There is no reason for the use of a mass measurement to imply that it
is the certificated maximum gross takeoff weight.
It could be:
1. The empty weight. This is how the part 103 definitions are
written.
2. The weight as actually flown.
3. The maximum legal gross weight at takeoff.
Since we do our flying on a planet with a fairly constant gravitational
accelleration, we can safely use mass or weight units of measurement.
Again, the international code refers to MASS because that is the way
that most of the world records these things.
(NOTE: often they measure with a spring scale, which is actually
measuring force, but it may indicate the mass (assuming normal earth
gravity).)
Alan
Old August 19th 10, 11:18 AM posted to rec.aviation.soaring
Gary Osoba[_3_]
On Aug 17, 9:56*am, Tony wrote:
Curious,
For the DU category, the 220 kg requiremnt is the all up weight. This
will need to be certified by the OO and the FAI is strict about it (as
they should be). The Carbon Dragon prototype (at 145.7 lbs. empty
weight) is a lightweight in this class. The Sparrowhawks weigh about
30 lbs. more and makes the weight easily as well. The Silent II WR
prototype was built specifically to meet my all up weight, and the
builders even resorted to special titanium fittings in some areas to
make it. I flew a straight line flight of about 1,000 km in it but
didn't file the world record, planning on exceeding it but then
falling short due to weather. Leo is lighter than I am and had more
spare weight in it. Some of the lighter Woodstocks, such as mine, also
make the weight if the pilot is not too heavy. I weigh about 180 lbs.
There are other light gliders now but the ones above are those I have
personal experience flying world records with.
Best Regards,
Gary Osoba
Old August 19th 10, 04:42 PM posted to rec.aviation.soaring
Dave Nadler
Best Regards,
Gary Osoba
Curious, how come you omitted Sigma from the list ?
See ya, Dave
Motorglider Definition Doug Hoffman Soaring 0 December 6th 08 07:27 PM
Definition of CFIT? Roy Smith General Aviation 4 March 31st 08 04:00 PM
Definition of a Veteran? Otis Willie Naval Aviation 0 March 26th 07 10:49 PM
Need A Definition Jay Beckman Piloting 4 May 11th 04 04:41 PM
Cross-Country Definition (USA) Michael Stringfellow Soaring 16 February 9th 04 05:01 PM
