Removing oxidation from Cobra trailer trim rubber and plastic fenders
Old September 24th 17, 07:43 PM posted to rec.aviation.soaring
Dave Nadler
Default Removing oxidation from Cobra trailer trim rubber and plastic fenders
I have an older Cobra with rubber trim strip (bottom edge of trailer top),
originally nice shiny red, now a bit dark and dull.
Anybody have a proven technique for getting the color back?
Similar for fenders?
Best Regards, Dave
Old September 24th 17, 08:12 PM posted to rec.aviation.soaring
Roy B.
Hi Dave:
On my Nimbus I masked the trim and hit it with Krylon brand "Fusion" spray paint. It bonds to plastic well. Also - Spindleberger sells replacement trim if you like.
Roy
Old September 24th 17, 08:13 PM posted to rec.aviation.soaring
Tom Kelley #711
Best Regards, Dave
Remove and replace with new! Also known as how to end bore doom during winter months.
Best. #711.
Best.
Old September 24th 17, 08:17 PM posted to rec.aviation.soaring
Roy B.
Spindleberger catalog calls it "protection stripe"
Old September 24th 17, 08:27 PM posted to rec.aviation.soaring
Tom Kelley #711
And Vendors here in USA sell this.
Best. #711.
Old September 24th 17, 09:42 PM posted to rec.aviation.soaring
Jim N
Best Regards, Dave
Use boat stuff avail at a place like West Marine. Suggest Inflatable Boat Cleaner
Old September 24th 17, 11:55 PM posted to rec.aviation.soaring
David Salmon[_3_]
top),
Best Regards, Dave
I painted mine when we re-painted the trailer.
Dave
Old September 25th 17, 09:32 AM posted to rec.aviation.soaring
If you replace the trim use blue not red
Old September 25th 17, 03:40 PM posted to rec.aviation.soaring
I did what Roy did, knock off the crud with wire brush and 80 grit sandpaper, then mask and shoot with rattle-can, changed to blue. I used 2" tape on top and a 3 foot piece of cardboard below the lip.......spraying 2 foot at a time with the can aimed down 45 degrees. I'm buffing the glass top now........good winter projects.
JJ
Old September 25th 17, 05:25 PM posted to rec.aviation.soaring
Dan Marotta
Default Removing oxidation from Cobra trailer trim rubber and plasticfenders
Curious - why blue instead of red?Â* Something to do with solar radiation?
On 9/25/2017 7:40 AM, wrote:
I did what Roy did, knock off the crud with wire brush and 80 grit sandpaper, then mask and shoot with rattle-can, changed to blue. I used 2" tape on top and a 3 foot piece of cardboard below the lip.......spraying 2 foot at a time with the can aimed down 45 degrees. I'm buffing the glass top now.......good winter projects.
JJ
Dan, 5J
Cobra trailer trim [email protected] Soaring 11 September 5th 13 04:54 PM
Cobra trailer wing dolly plastic sidewall rollers? [email protected] Soaring 4 May 9th 13 11:52 PM
plastic or metal fenders on the trailer? chris Soaring 14 December 20th 10 10:51 PM
Cobra trailer trim. Bob Soaring 12 July 19th 06 06:12 AM
Help - Cobra Trailer Trim? WDM Soaring 2 January 12th 05 08:47 PM
